Arkis
Message par Arkis »
Thank you!
Yes the VCI drivers are installed. The system is Windows 11 Home, 64-bit. Build 22631 (10.0.22631).
I can see in the Windows that the diagnostic tool is connected, but the diagnostic tool can't see the car.
Arkis a écrit : lun. juil. 08, 2024 11:21 am Thank you!
Hello
Good morning
It's normal that this doesn't work, because Diagbox 9.xxx only works with Windows 10 pro 64-bit and Windows 11 pro 64-bit
Gazou
Message par Gazou »
J'essai de coder l'autoradio sur un c4 space tourer 2019 mais impossible j ai un message d'erreur "erreur de chargement de cellule"
J'ai refait une installation mais cela n'a rien changé.
cordialement,
Arkis
Message par Arkis »
Today i tried to do clean install of Win 10 Pro 64bit.
Still the same problem. There was second (shorter) USB cable so I even tried that and it still does not work. Maybe there is something bad with the unit itself?
I tried to open it and snap pictures of the connections and boards. Could you please look at it if there is anything visibly bad?
Here is the link to the gallery of disassembled diagnostic tool. It should be in chronological order.
https://imgur.com/a/mS9UCA0
Some of the photos are in high quality. If you open it in a new tab, it will be larger than in the gallery.
Edit: Also scrap all about the light I said yesterday. On the OBD socket is a standalone mini flashlight with it's own battery. It is not connected to the OBD/diagnostic tool cables in any way.
Hello
Have you tried connecting to another vehicle to see if it works, no I don't see anything special on the VCI, but that doesn't mean anything.
Arkis
Message par Arkis »
Yes, I tried it on Peugeot 206, 2005 and Citroen C4 Picasso 2013 (mk II). Same result.
Gazou
Message par Gazou »
Gazou a écrit : lun. juil. 08, 2024 7:24 pm Bonjour,
cordialement,
c est bizarre car j'ai vu que cela marchait chez un copain avec la même version qui vient de ce site. Je vais creuser. Mais si on pouvait de donner une indication cela serait cool.
Gazou a écrit : mar. juil. 09, 2024 8:40 am c est bizarre car j'ai vu que cela marchait chez un copain avec la même version qui vient de ce site. Je vais creuser. Mais si on pouvait de donner une indication cela serait cool.
C'était sur le même véhicule que cela fonctionnait ?
citrotti
Message par citrotti »
La société
It World Services
Mohamed ElHachmi
11 rue Alexandre Dumas
60200 Compiègne
France
propose régulièrement sur ebay des interfaces originales d'occasion à un prix avantageux. Moi-même et des amis avons déjà acheté chez eux et ce sont de véritables originaux d'occasion - prix environ 130 - 145 €.
Il est probablement aussi possible d'acheter directement là-bas.
Description de l'article :
Dernier article ! !!!!
Profitez de l'offre exceptionnelle originale.
Rev C Lexia 3 PP2000 Et Diagbox Diagnostic Interface Citroen Peugeot A.1281 Z. Sonde PSA Lexia / Diagbox originale A1281Z Cbles ORIGINAUX Numrot A vendreoriginaldiagbox A 1281 Zinterface Authentique. Fonctionne Pour les 3 versions de DiagBox utiliser avec les outils de diagnostic Diagbox PSA Citroen / Peugeot , Citroen Lexia3, Proxia3 et Peugeot PP2000. interface et le cble obd 16 broches Interface seule, pas de logiciel Outil d'origine, pas une copie chinoise faite attention la diffrence une copie peut entrane de graves consquences sur votre vhicule. L'interface elle-mme et le cble de l'interface au connecteur rond sont authentiques et sont numrots en srie vous pouvez le voir sur les images. l'interface originale
Traduit avec DeepL.com (version gratuite)
Gazou
Message par Gazou »
[font]bonjour,
oui, citroen C4 space tourer 2019. Et le soft, il l'a eu sur ce site ! il a pu me modifier le VIN
Cordialement,[/font]
Heinrichkolb
Message par Heinrichkolb »
Hallo
Notieren Sie sich die Fahrgestellnummer genau richtig
Krugr
Message par Krugr »
salut la famille PSA-DIAG comment ca va en cette periode estivale?
dites moi je voulais savoir si bientot vous allez sortir une nouvelle version qui permettra de diagnostiquer les dernier vehicules (annees 2022/2023) comme tous le monde c'est les vacances vous etes surement au caraibe ou bien je vous le souhaite dans la penincule iberique profitez bien de votre repos et à bientôt la famille bonne vacances....
Krugr
Message par Krugr »
Torrentasos2 a écrit : ven. juil. 19, 2024 6:37 pm Tu pense que tout le monde a les moyens de se payer des vacances à l'étranger.
Et prendre l'avion c'est pas bon pour la planète
c'est pas pas croyable d'etre ausii negatif des la premiere reponse. eco comme tu parait l'etre rien ne t'empeche de prendre ton velo :D :D ​​​​​​​ :D ​​​​​​​ :D ​​​​​​​
Krugr
Message par Krugr »
si tu est aussi eco que tu le prétend pouquoi tu es ici? on fais du diag pour resoudre les probleme des utilisateurs de vehicules pour leur permettre d'aller bosser de niquer la planete avec leur carburant de merde quond est obliger de consommer pour vivre et nourir sa famille. c'est pas nous qui fesons les regles; on les subis!
Gilles57HG
Message par Gilles57HG »
Je n'arrive pas à faire fonctionner ma VCI, j'ai une PSA XS Evolution.
Je suis sous Windows 10.
J'ai essayé en machine virtuelle et une autre version de diag box, rien ne fonctionne.
le programme est installé, et quand je clique sur la 407, et que la VCI, est branchée, il ne la détecte pas.
Je pense que j'ai un problème de driver.
Si quelqu'un peut m'aider.
Gilles57HG
J'ai cerné le problème.
C'est ma VCI :
PSA EVOLUTION
AC 965250
Idem :
viewtopic.php?t=1615
viewtopic.php?t=1339
Je vais regarder plus précisément.
Mais si quelqu'un a un lien Amazon avec une livraison rapide pour une VCI compatible pleinement pour Peugeot 407, je suis preneur.
Je doit faire fonctionner DiagBox, j'ai une 407 coupé V6 2.7 , qui " clignote de partout ", et le bloc ESP qui fait un bruit de ronflement.
Gilles57HG
Bon j'avoue, je m'y suis pris comme un autodidacte, je suis allé à l'essentiel.
Et j'ai perdu du temps, et acheté une VCI foireuse.
Mais, cela m'a permis de bien comprendre les processus.
Je vais commander :  la VCI sur la page donnée.
Je n'ai pas de compte Ali Express, c'est pour ça que j'ai pris sur Amazon.
Encore merci.
Gilles
vw62
Message par vw62 »
Bonjour je viens d'installer la version 9.129 sans vm
comment puis-je l'activé
JCMATHIEU
Message par JCMATHIEU »
Diagbox 9.180 + MàJ 9.186 installée sur un PC dédié.
Manipulation réussie grâce aux 2 vidéos-tuto.
Merci pour le travail accompli qui m'a permis de réussir cette installation (sans déranger tout le monde!)
Bonnes vacances à tous et à bientôt.
Klein
Message par Klein »
JCMATHIEU a écrit : jeu. juil. 25, 2024 8:00 am Bonjour à tous,
C'est très bien, car effectivement il faut juste prendre le temps de bien suivre les tutos pour s'en sortir tout seul...
Il n'y a rien de compliqué dans l'installation de logiciels aujourd'hui.
vw62
Message par vw62 »
Sebos a écrit : lun. avr. 29, 2024 11:44 am Merci Grand Manitou pour ce partage comme d'habitude plus que généreux.
Je vais tester avec une XS Evo originale ;)
Torrentasos2 a écrit : mer. juil. 24, 2024 9:59 pm Si tu as fais ton installation correctement elle est activée.
Il faut lire les infos avant de se lancer dans une installation que l'on ne maitrise pas.
Mais comme d'habitude on fonce sans prendre le temps de lire.
Et ta version elle vient d'où, du forum ???
Bonjour oui du forum j'ai bien lu les instructions, il manque le ficher awroot
vw62
Message par vw62 »
Bonjour pour moi impossible j'ai le fichier d'origine en rar antivirus désactiver
smtncr001
Message par smtncr001 »
Hello, it has been like this for about 10 minutes. What is the problem? ODIS SERVICE is installed on my computer. Could it be a conflict?
My Computer Windows 10 64 bit Pro
Jo21460
Message par Jo21460 »
Merci sa marche impeccable sur Windows 7 cdlt ;)
Dan71130
Message par Dan71130 »
smtncr001 a écrit : sam. juil. 27, 2024 8:48 pm Hello, it has been like this for about 10 minutes. What is the problem? ODIS SERVICE is installed on my computer. Could it be a conflict?
Bonjour à  tous.
Je connais aussi le même pb. Je suis sous w11pro. J'ai avast en antivirus. Je pense tout bien faire à l'install, hélas au lancement,  ça reste coincé sur les 3 petits carrés vert qui tournent indéfiniment. Si quelqu'un à une solution, je suis preneur.
Bonjour, j'ai regardé à nouveau les vidéos de l'install, ça se passe tout pareil quand je fais l'install. Pourtant j'ai sûrement loupé quelque chose mais je ne vois pas où ? Le logiciel peut-il se lancer sans la vci connectée?
Si quelqu'un a eu le même pb et qu'il s'en soit sorti, j'aimerais bien savoir comment.  Merci.
Dernière modification par Dan71130 le ven. août 02, 2024 3:01 am, modifié 2 fois.
Debian
Message par Debian »
Jo21460 a écrit : lun. juil. 29, 2024 10:13 pm Merci sa marche impeccable sur Windows 7 cdlt ;)
Je pensais que cela ne marchait que sur Windows 10 64 bits ? Il y aurait une version 9.x fonctionnant sur Win 7?
Krugr
Message par Krugr »
Torrentasos2 a écrit : ven. juil. 19, 2024 9:31 pm Impressionnant ta rhétorique digne d'une personne qui veut se donner bonne conscience mais contradictoire.
Et ceci sera ma seule intervention alors si tu compte venir m'asticoter se sera peine perdue j'ai donné dans ce genre d'embrouille.
salut Torrentasos2 se n'etait pas dans mon intention de t'asticoter! j'ai juste repondu as ton message qui était négatif pour ma part donc pas d'embrouille... longue vie au site :D
frenchyz44
Message par frenchyz44 »
Pouvez vous m'aider svp, lorsque je connecte mon xsara picasso 1.6 hdi de 2004 avec la dernière version diagbox psa diag, je choisis xsara picasso il me trouve le code vin et lorsque que je dans pièces de rechange, cela me met motopropulseur essence et donc je ne peux pas accéder à tte les fonctions... c'est la merde car presque tout ce passe dans cette rubrique ... du genre coder injecteur ect ... le code apr est bien les 5 premiers chiffres qu'il y a sur l'étiquette de la porte conducteur svp ? J'ai mis 10094 peut être je me trompe mais je pense que c'est bon ?
Pourriez vous aider svp ...?
Merci d'avance pour vos réponses...
François
frenchyz44 a écrit : mer. juil. 31, 2024 10:06 pm Bonjour
François
L'interface bascule sur Lexia ou tu restes sur Diagbox ??
Dan71130
Allez, les gars soyez sympas, aidez nous......?
Dan71130
Dan71130 a écrit : mar. juil. 30, 2024 5:34 am Bonjour à  tous.
Bonjour à tous, je "reposte" mon message car je n'arrive toujours pas à m'en sortir. Merci de me lire.
Lemecanonovice
Message par Lemecanonovice »
Bonjour, un grand grand merci a toi pour le logiciel !!!
franckardeche
Message par franckardeche »
salut
ayant la 9.14 peux t'on mettre a jour avec la tienne?
merci a toi
Pisti09
Message par Pisti09 »
[font][font]Je vous remercie beaucoup.[/font][/font]
Krugr
Message par Krugr »
Dan71130 a écrit : ven. août 02, 2024 3:10 am Bonjour à tous, je "reposte" mon message car je n'arrive toujours pas à m'en sortir. Merci de me lire.
salut dan71130 ton probleme c'est pour commencer ton antivirus et windows 11 perso moi sous windows 10 pro 64 sans antivirus ni pare feu j'ai aucun probleme pour faire fonctionner cette version merci a l'équipe pour cela
Krugr
Message par Krugr »
surtout que meme pour les professionnelle de l'automobile il est déconseiller d'utiliser win11
Krugr
Message par Krugr »
Torrentasos2 a écrit : jeu. août 01, 2024 10:42 pm Reposte ton problème au lieu d'implorer
entierement d'accord il faut lire les sujet et surtout bien prendre en compte la config
Dan71130
Krugr a écrit : sam. août 03, 2024 11:03 pm entierement d'accord il faut lire les sujet et surtout bien prendre en compte la config
Bonjour @Krugr
Je ne savais pas que la config w11 pro était déconseillée vu qu'à l'install il est écrit qu'il faut w10 pro ou w11 pro en 64bit. Pour l'antivirus Avast, je le désactive avant téléchargement, tout au long de l'install et pendant le lancement du programme. Pareil pour défender.
Je vais regarder côté doublons, refaire un essai et laisser tomber si je n'y arrive pas.
En tous cas, merci de m'avoir répondu.
Krugr
Message par Krugr »
Dan71130 a écrit : dim. août 04, 2024 10:11 am Bonjour @Krugr
effectivement sous win11 il y en qui arrive a faire fonctionner je pense que ca dépend de la config perso je suis tech chez peugeot et dans le bandeau d'information il est bien stipuler de ne pas mettre a jour vers win11. c'est pour cela que a la maison j'ai une version win10 pro en 64 et ca fonctionne impeccablement bien avec la version du site! si tu veux pas reinstaller ta config prend un autre pc juste pour le diag il y en des pro type thinkpad pas tres chere mais surtout prend en compte la config processeur et ram
C'est surtout une mise à jour de Windows 11 pro qui pose problème.
